I have an Aluminum blower that has TCE fume passing through it at roughly 2500ppm at a flow rate of 600cfm. The blower wheel and housing is Aluminum. The wheel and fan internals have a surface area of approximately 7.5sqft.
I am trying to calculation a rough estimate of rate of corrosion. The unit has ran for about 2 months and shows a greenish oxidize inside which appears scaled over. Curious to know if the oxidize act to stop or slow the rate of corrosion of if i would expect continued corrosion.
Any advise is appreciated.
