Tekla AutoDesign
ikonstruktor
Hi everyone. Started learning Tekla 2016i. Now trying to check connection. I have started with 141 component, but it does not work with tie force, does not check welds when angles are shop-welded. Does anyone have the same problem & how to resolve it? Great thanks for your attention. (Sorry for my English)
I have been working toward using Tekla for 3D design. Are you using Tekla Structures? I don't believe Tekla Structures has a connection code checking function.
If you are leaning the program I would highly recommend taking the online class. I did and it was a big in getting started with the program.
