Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Spiral wound gaskets confined by grooves are okay for TEMA R, but spiral wound gaskets confined by stud bolts are NOT. Ask your shell and tube heat exchanger manufacturer. They should be able to explain what's required for TEMA R service. Also see page D-20 of the Garlock catalog below to distinguish what's confined and what's not...An outer ring is a way of confining a gasket. So if I were to use a spiral wound gasket and add an outer ring to it, it would be confined and ok with TEMA R.
Kammprofile is not considered a SOLID metal gasket. It is considered a semi-metallic gasket because it has metallic and non-metallic components.Is a camm profile to be considered under solid metal gaskets or not?
A Kammprofile (whether it has an outer ring or not) is confined if it is contained in a groove. Most of the TEMA R STHE's I've handled (back in the 90's) had the gaskets confined on the OD, usually male-female types. I've never heard of a Kammprofile with inner ring.Is a camm profile without outer ring confined (inner ring is present and is used to align)?
