Hello. I have a question concerning the isenthalpic expansion of steam across a control valve (please assume that the pressure drop across the valve would result in a temperature drop and result in dry superheated steam). Say for example the upstream steam temperature was 400°F and the downsteam temp. was 300°F superheated. Where would this temperature actually occur? Would it be immediately downstream of the CV or would it take sometime to decrease from the upstream temperature of 400°? I understand that for this example the temperature would drop, but I don't think I understand where the removed heat goes and how it is not transferred to the steam passing through the CV. If the heat is lost to friction, it seems the body of the CV would increase and keep adding to the downstream temperature and that the effects of the 400°F upstream temperature would be felt on the outlet of the CV. Any explanation on this would be greatly appreciated. Thanks.
