jrrocks
- Aug 13, 2018
- 58
We usually measure SA temperature using digital thermometer's wire probe in line with the flow. I have been informed to take temperature of supply air grill surface using IR thermometer, instead of air flow . I believe, there will be difference in temperature when reading taken on SA grill (using IR) surface and reading taken on Supply airflow (wire probe). Both would not be same.
we are about to order IR thermometer for this work. I need advise, whether it would be worth buying it because I believe, wired thermometer reading will be more accurate than grill surface temp. We need air flow temperature while calculating Tonnage, not supply air grill surface temp.
