Temperature correction factor
Trident kanna
What will be the formula for finding temperature correction factor in air dryers?
You need to elaborate. Are you referring to temperature correction factor to determine appropriate hydrotest pressure? Confirm the vessel is designed to ASME Section VIII, Div. 1 or if it's another code. From there you can receive further direction.
Thanks,
Ehzin
Yes the code is same but looking for working temperature.
kanna.
