hapetter
- Apr 12, 2002
- 28
Hi.
I have an application where i want to control the temperature in a room with a resistive load, Controlling the load with a PLC.
Ok so im going to use a powercontroller. The power controller takes 4-20mA and controls the load 0-100%. To be able to control the temerature due to a temperature reference, then Im going to use a closed loop PID control approach.
So I have a PLC, a temperature probe (PT100), and a powercontroller.
So I have some basic control question, starting with this:
The setpoint to PID is in degree Celsius. Lest say the setpoint is set to 30 degree Celsisus, then if actual value (temperature probe) is 30 degree celsius as well, then there is no error and the output of the PID is 30 (steady state). So how can I make this into a 4-20mA signal? If it is in steady state, then there should be no power, hence it should give 4mA to the powercontroller.
Thanks!
Best Regards
Hans
Thanks!
Best Regards
Hans
