temperature point , not match in heat transfer & stress analysis
mehrafarid
15
Hi
I am modeling a shell elements for concrete slab with reinforcement.
2 files: 1 for heat transfer (Heat transfer) and another for stress analysis (static,general)
I checked that section have the same integration point (5) for both files.
When I run the stress file,I have following warnings:
The number of temperature points 3 for beam or shell section found on the output database is larger than in the current model. This number must match between models.
Also I do not have any stress, deflection for temperature (maybe because of above warning)
