At work we have this vacuum furnace and I used Orton Temptabs to map the temperature uniformity in the furnace. I am pretty sure they made my parts oxidize and turn blue. Does anyone have insight as to why this would be happening or have any resources that I should check out. The Temptabs are supposed to be pretreated so that binders will not burn off in the oven but something is still causing oxidation. Thank you so much for your time.
Sincerely,
Troy
Sincerely,
Troy
