Need to find the tensile capacity of a bolt in a tapped hole condition.
Lifting a tank that has 6-3/8" tapped holes about 3/8" deep. Tank flange is Cu-Ni and weighs about 5,000 lbs. Considering FS of 2 on lift and additional 20% for prying action on bolt heads. Therefore I need a 2,000 capacity per bolt (looking at A307 or Grade 5 if available). We have a lifting lug (1" thick plate) that will be bolted to the flange via the six bolts.
How much thread engagement do I need for full capacity of the bolt (assuming steel base material)?
Can I calculate the reduced capacity if less than optimal thread engagement?
How do I determine capacity of connection based on shear strength of actual base material?
