tension strength for concrete
robyengIT
894
as far as You know, there is any literature about relation between tensile (not compressive) strength of concrete directly found in lab (with proper specimen) and the tensile strength indirectly found in lab with the cylinder specimen (brazilian test) ? Usually the standard provides a formula stating the tensile strength from the failure load of the brazilian test
To my knowledge, there is no credible direct tension test for concrete. This is because there are many variables that affect concrete tensile tests. For instance, even a slight variation in distribution of the coarse aggregate in the concrete will change its tensile properties but not affect its compression properties.
The two common tests are splitting tensile and flexural tests. It is easy to do a correlation between splitting tensile and flexural as you can use the same specimen for both tests.
Here is a link to some additional information.....
Concrete Testing
A Great Place For Engineers to Help Engineers
Follow me there.....
Here is some literature that may feed your quest.
Report DSO-2018-11 "Developments for the Concrete Tensile Split Test" - Dam Safety Technology Development Program Link
Report DSO-2016-02 "Concrete Tensile Strength Specimen Size Effects" - Dam Safety Technology Development Program Link
Publication Number: FHWA-HRT-06-103 Date: August 2006
"Material Property Characterization of Ultra-High Performance Concrete" Link
