Term "CJ El"
lookintomyeyes
55
Quick question as I'm a mechanical engineer having trouble understanding a drawing.
The drawing is for the detail plan and elevation of a retaining wall, and it keeps noting "CJ El". I'm assuming this references a certain point/elevation, but I'm having trouble finding the original "CJ" on one of over 50 dwgs.
Is the abbreviation "CJ" a common one? What does it stand for?
Thanks in advance!
I normally think control joint for CJ. I could also be construction joint. What is the wall construction?
Is there not a legend of abbreviations?
My first thought when reading your question is "construction joint". Since it is a retaining wall, I feel certain of this.
The "E" could possibly mean "each". Is the last letter an "I" or an "L"? Is it a tall wall perhaps over 10 feet? If L, it could mean "each lift" or each concrete pour. Tall walls must be placed in multiple steps if it is a tall wall which means multiple construction joints.
Const. or control joint "E1"....is there a reference to a section expressing an E1 joint?
To follow up on jsdpe, coudl it be Construction Joint ELevation?
