jpjamo
- May 4, 2005
- 30
Hi Guys,
I am a mechanical design engineer at a company that manufacture commercial filter coffee brewing equipment and hot water boilers.
I apologise in advance for a 'not well posed problem' due to my lack of EE background but here goes.
We have been seeing some burnouts between the heater element tabs and the flat 'quick connect' terminal that is attached to the element tab.
The elements we use are nearly all 2.8kW with supply voltage at 230V.
The element tab material can be either stainless steel or nickel silver.
As far as I read, these materials are both rated for fairly high temps - in the region of 200degC +.
Our element supplier has confirmed that the steady state temp of a tab when the element is energised tops out at about 90degC.
The crimp terminal we use are of the flat quick connect type. Apparently in years gone by we previously used elements with screw terminals and wires with crimped pin terminals.
We changed from this some years ago to the 'quick connects' to improve assembly/serviceability and also to be inline with our competitors.
It now seems that the 'quick connect' crimps may be the source of our problems though. I have taken temp measurements on the Neutral side of the element (which seems to have as much issues as the live side) and if the crimp is in any way loose or 'jiggled' around it is possible to get temps quickly up to 150degC at the connection – obviously because of increased resistance seen at the connection.
One other change that was made a number of years ago was to add in an 'insulating sheath' (basically a 50mm long piece of 12.5mm ID silicone tube). This tube covers from the thread section of the element right over and past the terminal connection - see photo.
The temp at the connection can get hot enough to burn through the silicone tube – or turn it into a crumbly white mess.
This tube is meant to give more protection to service engineers if they took the machine apart without disconnecting first, but I am also wondering if this is contributing to our issues?
So my main query though is - are these 'flat quick connect' type of terminals reliable at all?
Should we just go back to the 'belts & braces' solution and use the pin terminals with screw connections on the element?
These quick connect terminals seem quite prolific amongst out competitors and other commercial cooking equipment though, so I figure they should be reliable enough!!? Are there different material types for these terminals that are better than others?
Any thoughts/comments/requests for more info or photos will be greatly welcomed.
James
James
