I'm having fun with Idle Air Control Valves (IAC)...
What would happen if I applied 12 volts to one coil?
How do these work?
I know these are "stepper motors", but have no experience with them at all.
As with everything automotive, I'm having a hard time finding technical information which explains how they work. Do they get a "square wave" and many 12V peaks to make them move?
Do you send a 12V off/on/off signal to one coil, then a 12V off/on/off signal to the other coil and alternate to get the motor to "step"?
Reverse polarity to get it to go backwards?
I'm going to get one from a wrecking yard to play with, so if damaged, no harm done...
How do these work?
