compositeFEA
- Jun 26, 2011
- 9
Hi everyone,
I am working on a design project and I need to find some special lighting equipment. The problem is that the lighting device will work in hostile environment, i.e. hot and wet. The temperature can be as high as 250F (120C) and the relative humidity can be around 95%. The lights will be placed in an environmental chamber for illuminating the test that is going on inside. Do you know about companies that could help me out choosing the right lighting solution? Or do you have any experience/advice that could give me an orientation?
Thank you!
Thank you!
