Testing oil pipe with 150 bar and failing
Bilegt
1
Hi guys. I need your help
We installed 240m oil pipe and tested it with 150 bar. But it is leaking every coupling and union.
Any solutions, we tried our best we tightened as much as possible.
A few more details perhaps like
Design pressure, design code, size of pipe, type of "coupling" and Union.
Or are these API 6A hammer unions?
Options - dismantle and clean every end, remove all dirt, chips, gouges, scrapes etc
Add some sealing paste
Get a bigger hammer
Get a stronger operator
Buy some proper pipe and weld it
LittleInch's last option is usually the best. Sounds like a higher pressure for it to be threaded and coupled and not expect this to happen.
To be fair API 6A hammer unions go to 20,000 psi but they are pretty basic things and get treated terribly by drillers.
What kind of pipe ? What kind of connections ; there are hundreds for API casing. Why unions ?
150 Bars is a high pressure, the rating for couplings unions and flanges shall be according de high pressure test and from what do you say it seems a design project error.
