andriver
- Apr 29, 2015
- 154
My company is doing some work in a plant that has an existing horizontal lifeline comprised of wire rope that runs to a turnbuckle which is connected to an anchor plate in concrete columns. I do not have any details on the embedment for the anchor bolts in the anchorage point and I was wondering if we could load test the horizontal lifeline to approve it as a tie-off point.
I did read in OSHA "Personal Fall Arrest Systems - Non-Mandatory Guidelines for Complying with 1926.502(d)" that "Testing of installed lifelines and anchors prior to use is recommended."
What tests would you conduct, are they the same as those you would conduct for a body harness? The phrase "testing installed lifelines prior to use" implies that testing the system does not automatically exclude a tested system from being used in service.
What procedure would you all recommend for testing a lifeline to demonstrate its adequacy for service?
