Texas PE Documentation
andriver
154
I will have the necessary PE experience beginning July, 2016 which will allow me to get my application in the nick of time for the October, 2016 PE exam.
I have done a decent job cataloging my experience by creating folders of all the work I have done on my computer. I need to start putting this experience down on paper. Would anyone have a template of how this experience looks on paper for the Texas PE? Their website states the following:
"While gaining experience, it is equally critical that you document it in such a way that you can summarize it for the Board. As you go about your weekly tasks, you should keep a detailed diary of your activities: the starting and ending dates of the project(s) on which you worked, name and address of each employer, job title(s), the name, present addresses and phone numbers of the engineers and other persons with which you personally worked who can serve as a reference to substantiate your experience, identification of the project, the scope of the project, and the engineering activities that you personally performed."
I work for a large construction company and most of my work is as a temporary structures engineer as well as heavy lift designer. I may work on 5-10 projects in a year, throughout the year. So I may work on project A this week, project B next week, and jump back to project A 3 weeks down the road. So my project start and end dates would not be chronological because I hop around. Any advice for dealing with that?
Also, I am debating taking the Construction PE just because it looks easier, then I would take the Structural PE the following 6 months. I am not sure if I ever would try and take the SE, took my bosses several tries and I feel they are way smarter than me. Any thoughts on taking the "easy" route by doing Construction PE first?
When I applied for my PE, I had been working in a similar role for a large GC. I didn't apply in Texas, so it may not be an apples-apples comparison, but I listed the experience as one engagement (with my dates of employment), explained my general set of responsibilities and duties, and then listed the dozen or so projects with some generic details (analyzed a lift sequence in Alberta, designed falsework in Texas, etc) and without specific dates.
I also considered the construction PE, and it also seemed easier to me (except for having to know OSHA regs). In the end though, the majority of my work is structural even if in the construction arena, so it felt like a point of pride to take the test in structures. It would be cheaper though, if you don't have all of the structural references readily available.
As a geotech, I completed countless projects (several hundreds) by the time I was eligible and applied for my license. I just used a handful of examples from the simplest to the most complex that illustrated the breadth and depth of my experience.
