text override and control characters
urielcdc
15
I use the next code to add a tolerance to dimensions with “text override”
<>±\S1/4;"
The <> is getting the original dimension which is ¼ inch. (stacked format)
And the next part of the code gives me the ± tolerance with a stacked format also.
Now I have to do the same but my tolerances are different each other, one is -1/4” and the other is -1/8”.
I could use the next formula
<>\H0.6x;\S+0.25"^-0.125"
But this formula gives me the tolerances in decimals.
How can I do this but with the tolerances in fractions stacked?
Hi urielcdc
try: <>+\S1/4;-\S1/8;
Should get you what you need.
HTH
Todd
Thanks TCARPENTER1 but what I was trying to do is like in my example
but instead of decimals, have fractions, but keep the tolerances positive over the negative.
With your formula the positive is next to the negative.
What i want to do is something like this:
<>\H0.6x;\S+¼"^-½"
But I cannot do that for fractions that are not included in as a caracter in the fonts(1/8 for example).
urielcdc,
I think you have to use ACAD Mechanical ose...
Or you can make an own Dimstyle, but that's without fraction stroke too.
ADT 2004
