Albigger
Aerospace
- Dec 29, 2004
- 204
We are using a modified ANXI.xml drafting standard and I'm sure this must be an option somewhere, but basically when we place a cumulate (ordinate) dimension, and then just place regular text, the spacing is not lining up. See attached .jpg for a screenshot of this. You can see the first line is the cumulate dimension with text afterward, while the last 2 lines are are just typed text. The spacing on the font and even on the numbers is not the same, even though the text size is the same, and they are both using "Swis721 BT" font (the only font our drafting standard allows).
I'm thinking this is either an internal CATIA issue, or there is a setting in the drafting standards I can change to correct this. Any help would be appreciated. Thanks.
