TFVE Motors?? 2
ThePunisher
384
Hi all. I am working on a Brazilian project which employs IEC type motors, type TFVE. I tried to get the meaning of TFVE and it sounds to be a totally enclosed motor with external fan. However, my motor is 45kW running at 1200RPM. This motor is operating a vibrating screen.
I have doubts whether this is a motor with an external fan with a separate power source OR a motor with a fan coupled to its shaft.
if somebody has used this type of motor before, I would appreciate if I be guided with my doubts. Thank you.
It should be TEFV = Totally Enclosed Fan Ventilated same as TEFC.
The fan is mounted onto the motor shaft at the non drive end.
No, TVFE is a Brazilian term: "Totalmente Fechado com Ventilador Externo". I'm sorry my Portugese isn't good enough to translate it with any certainty, but it does seem to be better than your ability with Google. [poke]
image.php
My translator (software) comes up with Totally Enclosed Fan External and/or Totally Enclosed Fan Outside. I did notice that the TVFE designation is associated with an IP 55 enclosure.
I got that far with the translation - so is the cooling fan on-shaft like a standard TEFC design or a separate blower mounted on the NDE cowling?
I don't think we are being much help to the OP, are we??
image.php
Scotty,
The best that I can offer is that the motors I've seen in my couple of searches online (for a TVFE) is they appear to be shaft mounted fans as in a TEFC. If I have time I'll try to back-track and furnish some links.
Thanks starkopete and all for the figures. I was thinking the same thing except that I have to get second opinion on this.
It is good to have helpful folks around.
