OK.. no where on the web have the small community of "pro/engineer migrated to UG" people put info for newbies moving from Pro/E Wildfire 4 to Unigraphics.
In Pro/E we are used to seeing auto-dimensions and constraints pop up in sketcher. all of which are weak until you confirm them as strong or leave them as is. In pro/e the sketches are always constrained when you exit the sketch. Can NX7 auto-dimension as you sketch? if so, how do we turn it on? I saw the Auto constraints function.
How to i make construction geometery in the sketcher in NX? In pro/e we can draw a circle or line and flip it to a construction entity. future extrusions etc, ignore the construction entities.
I have never seen so many numbers go flying across the screen as I do in NX7. In Pro/E the only numbers we ever see are the dimensions we modify. I am constantly seeing X Y and Z boxes everywhere.
I have lots of good things to learn as a veteran pro/e user of surfacing, cabling, routed systems designer, etc...
I look forward to a long discussion..
