The emboss die, how to do that?
Is it "one punch" and the complete sheet is done or "one punch per cavity" ?
I guess that a simple method would be to extrude the die cross section thru the sheet, then use Insert - Trim- Trim body.
Depending on the size of the extrusion you would get both options.
Regards, Tomas
Hey Thomas,
Thanks, that works perfectly, the emboss is done on one single punch.
The trim body gives exactly what I want.
Have a good day
