the factor m in calculating αm for global initial sway imperfections
GWZ@CN
1
Am I understand the m correctly? My understanding is that when calculate a single span potal frame,m always equals 1,because there alway be a column which Ned is less than the average.And for double span frame,which the inside column NEd is usually much larger than the other two,so m equals 1 most times.
I m confused because I saw a software tutorial vedio,in which the presenter input m=2 for a single span portal frame
m is the number of columns in a row including only those columns which carry a vertical load NEd not less than 50% of the average value of the column in the vertical plane considered​
I don't want to disappoint you but your interpretation is wrong.
As you have copy and pasted from EC -1993 ;
m is the number of columns in a row including only those columns which carry a vertical load NEd not less than 50% of the average value of the column in the vertical plane considered and for single span portal frames m=2
This is also not true. Consider symmetric double span frame with UDL total 16. The inside mid column will carry 10 units , the side columns will carry 3 units. The average column load is 16/3 =5.33 and 50% of the average makes 2.66 units. All of the tree columns resist more than 50% of the average value . So , m=3
I hope my respond answers your question.
