Burunduk
- May 2, 2019
- 2,404
In the ASME Y14.5-2009 standard, the SEP REQ is always shown attached beneath two or more feature control frames. If these feature control frames control patterns, it means that each pattern as a group is controlled in a separate set up of the datum reference frame, but the tolerance zones of the features of the pattern are still established simultaneously and are mutually fixed.
What if SEP REQT is only shown beneath one feature control frame associated with a pattern? Does the SEPT REQT in this case dismantle the fixed interrelationship between tolerance zones of features within that pattern?
