The Neverending Search 6
Neubaten
Industrial
Oct 29, 2006
129
It's been almost two years since I started working as an engineer, 6 months since I started in the aerospatial industry as a materials&processes eng. And there's this thing I noticed: 80% of the things I deal are not easy-access.
I mean, I always end up wasting time, stuck into finding what hell of an ASTM standard is out there for nickel alloy welding, or where I can find the density of the Whateverflom-Butidontnyl polymer or similar stuff.
It is not that I haven't got resources, we have handbooks, manuals, catalogues, access to standard-downloading pay websites and whatnot...
...but it happens more than usually that the component I'm searching for is highly marginal and with so few data available, and I have to look endlessly until I find the property I want into an obscure reference hidden into the darkest place of the archive or into a link in the internet, just before I was about to retreat.
I use this site a lot, and it helps, but sometimes it isn't enough.
Do you, senior engineers, have the same problem or is it that I haven't mastered the art of search or something?
Having a stick where I can collect things as I find them, to use for future searches might be a good idea.
Anyone experienced on the DocuWiki thing? is it really practical?
Maybe just a log file to index things and throw everything into folders might be enough.
Just started setting my Dokuwiki up. It really is as good as it claims to be.
It suits the way I work very well, I can write notes, with other files embedded. As wordprocessors go it is not much good for writing reports, and I haven't tried to print anything out yet.
The worst thing is tables, for which wikis, and browsers generally, have rather ugly syntax.
Cheers
Greg Locock
SIG:please see FAQ731-376 for tips on how to make the best use of Eng-Tips.
What I have tended to do is to set up an excel spreadsheet as my index file for either an individual project or data in general. I include the file name, description and then create a hyperlink to the file itself. As long as I do not move stuff around too much (or remember to update links if I do so), I have found that it works well. I can use excel's data sorting capabilities to help me find an individual file reasonably quickly.
I had a wiki at my last job I used heavly. I think the main use for it will be how much you enter in it. The one I had set up had all the major HP printers then you could pull up the most common break/fix routines, the manual, parts list and anything else I could figure out
Also I have heard you can have the wiki search pdf's to find what you are looking for this would be great for going through codes
Wiki/database, same things really.
Databases have two related problems:
1) When they are empty, they are boring.
2) Putting things in is boring.
If you can get over (2), (1) goes away.
- Steve
Hi Greg - Glad you like it. I came across it on a Formula SAE discussion thread about project management.
Ben
