the problem of installing abaqus 6.4
handa12737
Geotechnical
Feb 3, 2004
ABAQUS/Viewer
...ERROR
ABAQUS did not complete successfully.
Please see Viewer.log for details.
Turning off hardware acceleration may correct the
problem. See ABAQUS Online Support System Answer
1249 for details.
Continuing...
ABAQUS/CAE
...ERROR
Please see CAE.log for details.
1249 for details.
Continuing...
viewer.log:
<98 out of 99 licenses remain available>.
FXGLContextEx::create(): wglCreateContext() failed.
ABAQUS Error: ABAQUS/CAE Kernel exited with an error.
i have turned off the hardware acceleration in the graphicsconfig.env,
what is the problem?
thanks!
A workaround is to set the environment variable ABAQUS_KERNEL_VIEWPORT in your C:\ABAQUS\v6.4-1\site\abaqus_v6.env environment file. Edit this file and add the following 2 lines:
import os
os.environ['ABAQUS_KERNEL_VIEWPORT']=ON
/karelin
first thank karelin!
but,i still donot solve the problem,
i added the lines,but the cue:
1249 for details.
still exist!
expect your help!
thanks
Did you ever solve this problem? I'm having the same problems even after doing the hardware acceleration and 2 lines trick, ABAQUS/CAE and ABAQUS/Viewer have errors durring verification.
Thanks.
