The universe inside the Atom 1
The fundamental known forces are Gravitational, Electromagnetic, Weak nuclear an strong nuclear.
“In the span of 100 years, from Dalton to Rutherford, the basic ideas of atomic structure evolved from very primitive concepts of how atoms combined with one another to an understanding of the constituents of atoms—a positively charged nucleus surrounded by negatively charged electrons. The interactions between the nucleus and the electrons still required study. It was natural for physicists to model the atom, in which tiny electrons orbit a much more massive nucleus, after a familiar structure such as the solar system, in which planets orbit around a much more massive Sun. Rutherford’s model of the atom did indeed resemble a tiny solar system. The only difference between early models of the nuclear atom and the solar system was that atoms were held together by electromagnetic force, while gravitational force holds together the solar system.”
As Gerard ’t Hooft says is the Universe inside the Atom?
“Once upon a time there was a point, and the point exploded, and that gave the beginning of the entire universe. The beginning is very difficult for the scientists to figure out, but the first real picture was taken hundreds of thousands of years later. You can see here a completely homogeneous picture of the universe with microwave light. You have to enhance the contrast by a factor of a million to get these blotches of color, which became galaxies. A few billion years later you get this picture from Hubble, of young galaxies only a billion or so years old.
This universe is striking because it is controlled by the laws of physics.These seem to be the same everywhere else in the universe as far as we know it. That is a very striking thing.
Planets move in basically elliptical orbit around a central mass, like the sun if it’s heavier.
They move faster close to the sun and a little slower further away.
Another important characteristic of the universe is that it is empty. There’s a lot of space between the stars and planets. I want to say that inside the atom there is a similar universe.
There is a central unit called the nucleus with electrons moving around it in elliptical orbits.
The forces acting on the electron, you might thing, are just like those acting on planets, but the laws of dynamics for these electrons are quite a bit more complicated.
The actual way in which electrons move is dictated by quantum mechanics, which are probabilistic and difficult to control. A better picture would make these look like they’re out of control. But a closer look says that there are points where these never come and others where they come quite often. By having electrons come more often one place than another you get certain effects, which we call the laws of chemistry. But this is still a very poor model, the real laws of quantum mechanics are much more complex.
Interesting as the universe is, I want to concentrate on the nucleus at the center. If you look at the atom, the atom is much emptier than the universe electrons are maybe an angstrom from the nucleus, but the nucleus is a hundred thousandth this distance in diameter, compared to a hundredth factor in the solar system.
So I want to focus on the nucleus, made up of the two nucleons, protons and neutrons. A thing I’ll say much more about later, each is made up of three subunits, called quarks, and the study of these quarks has become a very important subject in the latter half of the twentieth century and continuing to today.”
My question: Can we assume that fundamental known forces work together as a complex system? In other words any kind of matter is submitted to all fundamental forces at the same time?
[atom]
Searching for the "Unified Theory"? Perhaps you can get Stephen Hawking to chime in with his opinion...
The most likely place for the next super discovery concerning such theoretical wonderings is here:
There are billions and billions of dollars being spent all over the world in search of an answer to your question.
You might also refer to the works of Brian Greene such as "The Fabric of the Cosmos" which talks about Newtonian, Quantum and the current String and Brane theories in physics. There are sections discussing elementary particles and conditions in the attempts to discover the physics within the early universe.
In the solar system planets orbit along the sun by gravity force.
In the atom electrons are attracted to the nucleus due to electromagnetic forces.
“Both are considered as a component of a bigger state; as the solar system, which is too big, is a small piece from the universe, while the atoms are a very tiny pieces from the molecules, which are in turn pieces from the substances and matters. And the difference here is that the atoms compose the solar system, while the solar system doesn't compose the atom!”
“There is a strong nuclear force greater than electromagnetic that keeps protons together in the nuclei. The strong force (so-called because it is stronger than the weak force) is only felt by quarks. It behaves like elastic, because the further apart you pull two quarks, the stronger the strong force gets between them."
"The neutrino has no strong or electromagnetic interaction and feels only the weak force. That is why neutrinos are so elusive that they can pass through the entire earth without interacting.”
“The actual way in which electrons move is dictated by quantum mechanics, which are probabilistic and difficult to control.”
