I'm currently designing a sacrifical zinc anode protection system for a steel sleeve (ASTM A36 #12,5 plates, surface area 25 m², epoxy coated) for HDPE pipe in seawater condition. The total anode weight calculated is 330 kg.
I would like to know if bolt zinc anodes (6 kg, way larger than needed for Ø7/8''x8'' bolts) can be considered as sacrificial anode weight for the steel plates or exclusively for the bolts.
Thanks in advance.
Thanks in advance.
