Thermal Conductivity Calculation Problems
Muttzy
18
I am trying to write a program that calculates the thermal conductivity of the material that I enter but it seems like I am having a problem with the temperature units and I was wondering if anyone here had an idea as to how to fix my problem.
I enter the data in a table and use cspline to find what the value should be between my data points but I ran into a problem with the units. It runs just fine when I do not include any units but when I tested it with all the units the values are off. I have included my equations with a test value.
Does anyone know what I am doing wrong?
 http://files.engineering.com/getfile.aspx?folder=79b14b92-3a62-43f1-92c3-82c1c76be721&file=Therm_Cond_Prob.xmcd
I forgot - the program I am using is MathCAD 15.
Your usage of units is not consistent; you used deltaF in the definition of your function, but you called it with F only.
However, while programming is great, and all that, it's unnecessary in this case:
TTFN
faq731-376
7ofakss
