What is the best way to quantify the effects of using an ASTM A193 B16 alloy stud with a threaded 1018 steel flange?
The thermal expansion coefficient of the stud is about 14 F^-1 and 1018 is 6.7 F^-1. Is there a standard regarding this? Is this difference something I should be concerned about?
The application is an automotive exhaust system so temperatures will cycle over 1000 deg F.
