Thermal load in load combinations
compe_ad
71
What will be the load factor for thermal load case in the different load combinations in IBC and ASCE ? Is it mentioned somewhere?
ASCE 7-16 Section 2.3.4 specifies a minimum of 1.0, but leaves it up to you to determine what that factor should be for your application. Take a look at the commentary.
