A Thermal PSV on a 4" steam condensate line lifts/pops when the condensate pump starts up. Then PSV reseats. The pump is 400kPa centrifugal pump with 40m head press max.
The PSV specs:
1. Conventional type
2. Set pressure is 1035kPa
3. Operating temp is 100 C and relieving temp is 171 C
According to the plant operator the PSV was good for many years and started lifting recently.
We removed the old PSV and replaced it with a new identical PSV. But the lifting/popping continues.
The steam condensate temperature is between 90 - 95 C. Also the condensate discharges into a cylindrical tank vented to atmosphere.
Anyone had a similar problem or can offer possible reasons for the problem.
Note: There has been no changes to this process recently.
Nova
The PSV specs:
Nova
