Payyan1234
New member
- Sep 26, 2017
- 17
I have a question regarding joint strength of an equipment , which is placed on a honeycomb core and backed by a doubler plate. Please see the attached picture.
The equipment sees high temperature around 102 degrees. I have analysed the joint by calculating the delta displacement from thermal expansion of two metal plates and assumed them to act as parallel spring K= K1 + K2 and found the The total force at the Joint using F= K. delta displacement.
This force is used for checking the fastener shear strength and joint bearing strength.
Is this the right approach or am i missing something??
