I'm currently working on a problem which involves looking at the stress involved on the material during the heating phase,
the Scenario is If I have two heaters, one heater producing a greater output than the other (i.e heater 1 = 50watts, heater 2 = 100 watts), although they both provide the same total energy in the end to raise the objects temperature by a set amount, Heater 2 will just heat the object up X times faster than heater 1. this part I understand
The part that confuses me is this;
If I work out the total stress for example is 100 pascals, how can I put that in terms of Heater 1 and heater 2 stress, As we know the faster you heat an object up the greater the stress on the object? compared to when an object is heated slowly
Is it fair to say if heater 1 takes 10 seconds to heat the object up you can divide the total stress by the heating time so
100/10 = 10
and if heater 2 takes 5 seconds to heat the object up you can do the same thing?
100/5 = 20
This would result in heater 2 producing twice the stress on the object compared to heater 1?
To Summarise Im asking how can I link stress to heating time?
Thanks in advance for any help
100/10 = 10
100/5 = 20
