Thermal transient analysis with ANSYS
MaxTemp2
14
Dear all,
I am trying to calculate a simple thermal transient problem in ANSYS Workbench 11.0 to see how it works to make later more complicated calculations. But I have a problem:
My model:
-steel plate (vary simple geometry)
-starting temperature: uniform 300C
-boundary conditions: 150C and 10000W/m2C at one surface, perfectly insulated at other 5 surfaces
-time: 100sec with automatic time-steps
The results show, that the temperature can go above 300C, what is impossible in real.
I tried to solve the problem with refined mesh, more substeps to apply the load, calculating a steady-state solution for the transient case´s initial condition, but neither of them worked.
Can somebody explain me the problem? Or simply run the problem in ANSYS Workbench 11.0 and tell me his/her results?
The input files can be found under the following link: OR the one at the end of the post.
I am using "ANSYS Academic Teaching Advanced" licence, maybe that is the problem. (I do not have any other licences)
Thank you for your help
MaxTemp2
Your boundary condition at the non insulated face seems kind of odd to me. I would have expected something like one or the other.
Dear sailoday28,
Sorry, but i do not understand what you wrote. Can you specify it, please? (For a convection boundary you need to specify film coeff. and ambient temp. also)
Try solving a simple one dimensional transient problem.
Such as at time = 0, temp distrib is known.
At boundary x=l, perfect insulation, dt/dx=0
At x=0, Temp is Ti OR
At x=0, flux is Q/A But note the OR. Two conditions are not specified at x=0
Is the 150ºC a "boundary" condition, or the ambient air temperature?
Is the 10kW/m^2-ºC supposed to be input heat or somehow representing forced convection out? It seems absurdly high for a convection coefficient.
TTFN
FAQ731-376
I think I understand what you mean sailoday. I dont know how to do a 1D analysis in Workbench yet, but I will try to put the load conditions (convection) at a different time, lets say at 10 sec. (Maybe tomorrow, now I should finish working :) )
IRstuff: The 150C is the ambient temperature (bulk temperature of water) and 10kW/m^2C is the heat trans. coeff. The actual problem would be: "cold" water (150C) is injected into a reactor pressure vessel which is at normal operation temperature and pressure. 10kW/m^2C is an estimated value, of course it depends also on the massflux of water, temperature difference etc., but it is a good approximation.
Is this for school? Student posting is not allowed.
TTFN
FAQ731-376
No. I am working for an institute and thermal-structural analysis of RPV is my theme.
Applying the loads in small time-steps does not work either.
Everytime I decrease (increase) the ambient temperature, there are parts on the plate, where the temperature increases (decreases).
Dear MaxTemp
IRStuff makes a very good remark. What is the 10000 W/m^2 heat source exactly? How big is the plate where it dumps it heat?
I would consider the following: when you do transient simulations you'll end up with the steady state system situation after some simulation time. (consider the input heat load 100000 kW/m2 constant!!)
In contrast with transient problems, steady states are (more) easy to calculate. Try estimating it!! on the basis of Input heat = output heat.
So, the first question you ask yourself after a transient simulation leading to steady state: is the steady state comparable with the estimated one? Then you'll get some feeling for the values simulated.
Greetings
Onno
Dear all,
I have found the problem. If somebody is interested: look at "Thermal Analysis Guide" in the documentation, 3.4.3.2/"Number of substeps per load step, or the time step size". Here you will find a formula, which MUST be used, to get good results in transient thermal analysis.
MaxTemp2
Ps.: To my defence: while reading hundreds of pages of documentation, someone can overlook these things at the first time.
Well, a good lesson learned... ;-)
TTFN
FAQ731-376
