Thermodynamics (vapour pressures @ different relative humidities)
danneman
1
Hello bright minds,
I have been searching for vapour pressures at +55 degrees celsius from 10 % relative humidity up to 100% relative humidity, and I have trouble finding these values, even on the physcometric charts that I find. Have anyone any good input to this, or what the vapour pressure is at these 'states', please give me our feedback!
Thank you in advance
BR
Dan Anderson
-You only live once, but if you work it right, once is enough!
At 55C water has one fixed vapor pressure. The partial pressure of water vapor will vary with relative humidity.
50%RH means that the partial pressure of water vapor in the air is equal to 50% of the vapor pressure of water at 55C.
Psychrometric charts are derived from the vapor pressure vs. temperature curve for water.
