Thermoformed tray design in SW 2
MattBD
Bioengineer
Jan 26, 2007
62
0
0
Is there a good tutorial available for doing thermoformed tray design in SW?
I'm playing around with using the indent and deform tools as well as some surfacing tricks. However, if someone has a methodology they'd like to share, I'm all ears. I tried searching this forum and Google and didn't find much. I can't search youtube at work, but I'll try at home and see if there are any videos that address this topic.
Based on what I'm seeing, it looks like I should model the parts to be packaged as dummy parts that are completely solid (no voids, etc).
Thanks for the help!
-Matt
I've designed a few of these. My normal workflow is to start with a solid block to simulate the extents of the tray. I then create a single cut feature that will nest the product the tray is for, pattern as required. I then apply radii as required to the cut features. Lastly I flip the model over and use the Shell command. Works great for transport trays and the like.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of these Forums?
Shell! I need to remember that these functions exist. A star for you. That sounds a lot simpler and probably ends up with a better result than what I was thinking.
I'll amend my previous post and say that radii should be applied prior to patterning, then shell it.
Don't forget about the shrinkage . . .
Draft and pull are also important. If you want interlocking, check with the vendor on the design of these critical features.
Hardie "Crashj" Johnson
SW 2008 SP4
Nvidia Quadro FX 1000
AMD Athalon 1.8 GHz 2 Gig RAM
