Apr 12, 2018 #1 Jaani Mechanical Oct 8, 2013 20 JP The thickness direction in Thick Surface command is normal to surface. How can I have a solid from a surface with flat ends? (In shell command in Part Design WB the ends of a solid are flat but how to achieve the same result from a surface?)
Apr 13, 2018 1 #2 jackk Mechanical Nov 22, 2002 1,306 US Add a top and bottom plane, and then split the Thick Surface with the planes. Upvote 0 Downvote
