An ASME VIII Div 1 vessel with 0 design corrosion allowance has thickness loss on the shell and nozzles.
>Can I calculate the minimum design thicknesses of these components using the original year 1995 design code and then use these as an additional margin compared to the actual vessel thicknesses? The actual/measured thicknesses are 20-30% greater than the calculated values, which is apparently an extra design margin/FOS that has potential to be used.
>Or should I conduct an API 579 analysis directly?
Best regards
Best regards
