Hi
I am looking for some calculation or information for stiffening of Blind plates for Hydrotest. The Plates avaialable aren't sufficient for the hydrotest pressure. The diameter of the pipe is 54". the wall thickness of the Pipe is 12mm. I tried calculating the required thickness as per the Sec VIII Divn 1 code. The Plate is proposed to be welded at the end of the Pipe.
The proposal is to weld stiffeners outside on the Plate so that the hydrotest can be done. Any calculations available for determining the size of the stiffening memebers ?
Any information/calculation worksheets in this regard is solicited.
Balu
Balu
