awesomeness
Materials
We have an ongoing discussion with a foundry about the thickness of a gated casting test block. The thickest section of the casting is 200 mm, but the foundry insists its within the standard by having the thickness of 162 mm on the test block, see highlighted in yellow.
My interpretation is that is has to be 200 mm, or minimum 50 mm if the thickness of the casting is below 50 mm.
Anyone here that can help with this?
