thinking of starrting a mechanical design business 4
4wheeldr
19
i am thinking of starting a business using Solidworks 2007. Most of my experience has been assigning part numbers and documentation. I do have a BSME and have received my 3D certificate while being out of work. So the only designing i have done is thru school and playing around doing tutorials and other ideas. How do i start to go out and get clients. Is there any chance this could work since i have never designed for a company??
Any of your thoughts would be greatly appreciated
With any endeavor you have to start some where you might as well start it when you’re young!!! Check this site out and look up “Engineering Your Start-Up (EYSU2)” it is on sale now and may be a good read. Also, I suggest that you start on the road to a PE if you want to have your own engineering company.
Good luck!
Tobalcane
"If you avoid failure, you also avoid success."
