danthedesigner
Industrial
- Jan 21, 2021
- 3
I'm engineering a small metal housing that has very limited space. We want to use a M0.8x4mm screw to assemble the 2 CNC aluminum housing parts together. Without increasing the size of the housings we can use a boss with .03" wall thickness, not including the threads. The bosses are anchored to the perimeter wall of the housings. Are there any engineering references for designing small parts like this? Do any engineers here work on smartphones or watches? If so, could you let me know if this wall thickness will work?
Thanks!
Thanks!
