This [b]ufs.Obj.DeleteObject(newCsys.Tag)[/b] Cause no error no delete
Ehaviv
Computer
IL
Hi
This statement ufs.Obj.DeleteObject(newCsys.Tag) Cause no error and no delete
can someone helpe.
after I the journal move the Csys to a new WCS location
I want to the delete the traling csys.
Thank you
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports System.Windows.Forms
Module nxj_dynamic_csys_dialog_function
 Sub Main (pattern_type() As String)
   showDynamicCsysDialog
   while ContinueOrRepeate() = 2  'Continue=1, Repeat=2
   End while
 End Sub
 Sub showDynamicCsysDialog()
  Dim s As NXOpen.Session = NXOpen.Session.GetSession()
  'Dim workPart As NXOpen.Part = s.Parts.Work
  Dim ufs As UFSession = UFSession.GetUFSession()
  Dim displayPart As NXOpen.Part = s.Parts.Display
  Dim theUI As UI = UI.GetUI()
  Dim markId1 As NXOpen.Session.UndoMarkId
  markId1 = s.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
  If IsNothing(displayPart) Then
    'active part required
    Return
  End If
  '9 element orientation matrix of specified csys
  'arrays are zero based
  Dim myCsys(8) As Double
  '3 element array: origin point of specified csys
  Dim myOrigin(2) As Double
  'tag variable used as input/output for the .SpecifyCsys method
  'passing a null tag into the function uses the current WCS as the starting csys
  Dim newCsysTag As Tag = Tag.Null
  'variable to hold the user specified coordinate system
  Dim newCsys As CartesianCoordinateSystem
  Dim response As Integer
  'If you want to know the option the user used to specify the csys, pass in a variable.
  'The initial value of the variable will control the default option shown to the user.
  'After the function returns, this variable will hold the actual option used.
  'optional message to user
  'MessageBox.Show("Orient manipulator to the desired location/orientation", _
          '"Specify Coordinate System", MessageBoxButtons.OK, MessageBoxIcon.Information)
  theUI.LockAccess()
    'if you don't care what option was used to specify the csys, simply pass in an integer
    'that specified the default method to show to the user
    response = ufs.Ui.SpecifyCsys("Specify Desired Orientation", 5, myCsys, myOrigin, newCsysTag)
  theUI.UnlockAccess()
  If response = Selection.Response.Ok Then
    'get CartesianCoordinateSystem object from tag
    newCsys = Utilities.NXObjectManager.Get(newCsysTag)
    displayPart.WCS.SetCoordinateSystem(newCsys)
  Else
    Return
  End If
 End Sub
  Public Function ContinueOrRepeate() As Integer
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim titleString As String = "NX Manager Clone Assembly === By Elbaz Haviv"
    Dim resp As Integer
    Dim messages(0) As String
    messages(0) = "Click Repeate to show dynamic Csys again" & vbCrLf & _
                  "Or Click Continue if WCS is set to bottom left corner" & vbCrLf & _
                  "and you are ready to select and mark components"
    Dim but As UFUi.MessageButtons
    but.button1 = True
    but.label1 = "Continue"
    but.response1 = 1
    but.button2 = True
    but.label2 = "Repeate Dynamic Csys"
    but.response2 = 2
    theUfSession.Ui.MessageDialog(titleString, UiMessageDialogType.UiMessageQuestion, _
                                                 messages, messages.Length, False, but, resp)
    Return(resp)
  End Function
 Public Function GetUnloadOption(ByVal dummy As String) As Integer
   'Unloads the image when the NX session terminates
   GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
 End Function
End Module
The .SetCoordinateSystem creates a coordinate system in the graphics window. If you get this return value from the .SetCoordinateSystem method, the call to .DeleteObject will work as expected.
Code:
    newCsys = displayPart.WCS.SetCoordinateSystem(newCsys)
Else
    Return
End If
Alternately, you can use the .SetCoordinateSystemCartesianAtCsys method, which does not create a csys object in the graphics window (nothing to delete later).
Code:
    newCsys = displayPart.WCS.SetCoordinateSystemCartesianAtCsys(newCsys)
Else
    Return
End If
Alternate option #2: Instead of calling the .DeleteObject method, you could use the .UpdateManager methods to delete an object. The example below creates a visible undo mark in the NX history. If this is undesirable, you could create the mark as invisible or delete the mark after it is no longer needed.
Code:
theSession.UpdateManager.ClearErrorList()
Dim markId2 As Session.UndoMarkId
markId2 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Delete")
Dim nErrs1 As Integer
nErrs1 = theSession.UpdateManager.AddToDeleteList(newCsys)
Dim nErrs2 As Integer
nErrs2 = theSession.UpdateManager.DoUpdate(markId2)
www.nxjournaling.com
Hi CoWski and thank you.
I actually used wcs set origin and matrix
that do not create a csys.
but your solution that not create a csys
is more brief.
Thank you very much.
Cowski
how I can save location and display state
of wcs and restore it later.
To save the location/orientation, the WCS has a .CoordinateSystem property that you can save to a variable before manipulating the WCS. At the end of your program, you can restore the WCS to the original position/orientation. The WCS also has a .Visibility property that you can get/set to query/control the visibility of the WCS.
Great. I'm very thank you.
Cowski Thank you for your help.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module dynamic_csys_dialog_function
   Dim s As Session = Session.GetSession()
   Dim workPart As Part = s.Parts.Work
   Dim originalCsys As CoordinateSystem
   Dim originalVisibility As Boolean
   [b]originalCsys = displayPart.WCS.CoordinateSystem[/b]
   [b]originalVisibility = displayPart.WCS.Visibility[/b]
   displayPart.WCS.Visibility = True
   [b]displayPart.WCS.Visibility = originalVisibility[/b]
   [b]displayPart.WCS.SetCoordinateSystemCartesianAtCsys(originalCsys)[/b]
 End Sub
 Function body_init_proc(ByVal select_ As IntPtr, ByVal userdata As IntPtr) As Integer
   Dim num_triples As Integer = 1
   Dim mask_triples(0) As UFUi.Mask
   mask_triples(0).object_type = UFConstants.UF_solid_type
   mask_triples(0).object_subtype = UFConstants.UF_solid_body_subtype
   mask_triples(0).solid_type = UFConstants.UF_UI_SEL_FEATURE_BODY
   ufs.Ui.SetSelMask(select_, UFUi.SelMaskAction.SelMaskClearAndEnableSpecific, _
                                                          num_triples, mask_triples)
   Return UFConstants.UF_UI_SEL_SUCCESS
 End Function
    Return
  End If
  theUI.LockAccess()
    'that specified the default method to show to the user ---  2 = x-axis,y-axis
    response = ufs.Ui.SpecifyCsys("Specify Desired Orientation", 2, myCsys, myOrigin, newCsysTag)
    [b]newCsys = Utilities.NXObjectManager.Get(newCsysTag)[/b]
    [b]newCsys = displayPart.WCS.SetCoordinateSystemCartesianAtCsys(newCsys)[/b]
  Else
    Return
  End If
 End Sub
 End Function
End Module
