USMechE6
- Sep 21, 2016
- 50
Hi All,
I'm selecting a thread standard for a nominal 1-9/16" diameter engagement, but am confused by what I see in Machinery's Handbook. The internal threads/inch of 6, 8, 12 and 16 are all listed as UN, then 18 is listed as UNEF and then 20 is listed back at UN. Can anyone explain why the 20 threads per inch would not even be considered fine-pitch while the 18 is listed as extra-fine?
I like the slightly greater clearance the minor diameter of the 20 will provide for a solid piece that has to fit thru before the externally-threaded feature comes in, but I am aware of the pros/cons associated with coarse/fine/extra-fine, so I want to make sure I understand the basis for this designation. Some of the other nominal diameters have this, too - 1-1/2", 5/16" to name a couple.
- Eric
- Eric
