thread794-439534 Greetings to ev
Jagmtr
23
thread794-439534
Greetings to everyone
I have come across in very strange situation
I have reverse flange which was designed for grooved metal gasket having m & y value
Now I am looking to qualify this flange for diaphragm gasket which is having m=0 & y =0
I was thinking that my flange thickness will decreasing by changing m & y equal to zero
But my flange thk is increasing
Please guide me how to come out from this situation
Thanks in advance
Jagmtr, not much to go on there... (No, I am not asking you to post your calculations)
I'd assume something(s) in addition to m and y values has changed. I'd expect you'd need to carefully compare the two sets of calculations to identify and determine the effects.
Mike
Thanks sntman
I followed your suggestion.
Pitch circle diameter, large hub thk & gasket od could reduce flange thk
I choose to increase gasket od & now problem resolved
