Threaded TEE for 9 5/8" casing 1
jorgerobles
5
Hello, for an experimental setup I need to connect a 6in pipe line to a 9 5/8” casing. I wonder if there is any kind of standard piece that I could use (or modify to be used) as a tee.
Thanks,
JR
What ever way you look at it you will need a tee, you can use butt weld tees, this is a non stock item but can be manufacturers just find a graded fitter (G6 standard) API and have them prefab it for you. they will need to know the cold working pressure (CWP) and the test pressure
The CWP is the pressure you expect to be running through the pipes
You can then add or cut threads or if it is to be permanent weld
