I'm having a problem creating an internal thread. The hole cylinder is 0.4 inches diameter. Accoring to PipeThread.txt, the hole needs to be modelled on an internal minor diameter of .358 inches for a hole size of 0.405 Problem is Solid Edge rounds up to 2 places of decimal. If I set the hole diameter to 0.358, as per PipeThread.txt, Solid Edge kindly rounds this to 0.36. I then cannot create the thread as the hole size is not matching what is in PipeThread.txt Is there an overwrite to the rounding, or am I going about it all wrong? Any enlightenment would be helpful on this.
