three-dimensional earth pressure
fififififififi
Hi guys,
I'm Fafo from Italy.
How can I consider the dimension along y axis (see figure) on the calculation of earth pressure in a gravity retaining wall?
Per unit of length. For example, in imperial units, the pressure at the bottom of the fill would be in psf/ft. If metric, you might use something like kPa/m (I don't use the metric system often, so my units might not be correct with conventional practice).
Ron is correct.
However, I assumed you were interested in how to account for earthpressures acting along the y axis. Unless the ground slopes significantly in the direction of the y axis, there is no unbalanced load in that direction. Therefore there is no affect on the wall.
Mike Lambert
Thanks for the reply.
For walls with different height along the y axis, can I still apply Coulomb theory? Maybe, applying Coulomb to account for earth pressures acting along the y axis, I overestimate the thrust or I neglect any three-dimensional effect?
Generally 3D affects are neglected. I can't think of a single time i've considered them in 24 years.
Mike Lambert
I should have said that i've never considered 3D affects on the earth pressures for retaining walls. I have considered 3D affects in many projects over the years.
Mike Lambert
Thanks!
I know, in a retaining wall project the 3D effect are neglected; mine was a "theoretical curiosity" . In your opinion, is it possible still apply Coulomb theory?
Whatever theory you are using, pressure is the same in all directions.
Not in any theory modelling soil behaviour reasonably accurately.
In answer to the OP, the soil won't be close to an active state in the Y direction, so normal retaining pressure theory would not be applicable. A 3D FEA would be the best way to get a reasonably realistic picture of what is happening.
Doug Jenkins
Interactive Design Services
I don't know what made me say that. Soil is not a liquid or gas, so the pressure is not equal in all directions.
IDS say : "A 3D FEA would be the best way to get a reasonably realistic picture of what is happening."
Correct! Using finite element code (for example Plaxis3D ?!)
But do you know any analytical method to solve this problem? Do you know any issue (or publication)?
